GB3MX Still not Accepting Incoming AllStar Connections
:satellite: GB3MX AllStar Connection Update
:large_blue_circle: Current Status:
Since the move to Workington, GB3MX is not currently accepting incoming AllStar connections. This is due to the router at the site being locked down.
:wrench: Planned Fix:
I will attempt to resolve this soon with a VPN. However, this does not affect its normal operation, as it is still outbound connected to the CumbriaCQ network.
:busts_in_silhouette: Who is Affected?
:white_check_mark: End Users: :x: No impact – Everything works as usual.
:x: Node Owners: Only those trying to link their nodes to GB3MX will be affected.
:pushpin: Best Alternative:
:link: Instead of connecting directly to GB3MX, you should connect your node to:
:heavy_check_mark: 601040 – Hosted in a datacentre (Best option)
:heavy_check_mark: 601041Backup node at my QTH
:hammer_and_wrench: I will update you once this is resolved! :arrows_counterclockwise:
