Ok, big day - GB7KSE is now up and running fully - 25w output on 144.925MHz AFSK 1200 baud
If you fancy having a go (bear in mind I live down a hole) you’ll need a couple of bits of software (or one bit and a hardware TNC if you’ve got one and the cables in a cupboard
Software:
The first one is a modem, it modulates and demodulates the noises in the right order. But is can only do this. It needs something to tell it what to do, i.e. a terminal programme, which is the second one. They can be a bit fiddly to get your head round but they are no harder that setting up FT8 or any other digital mode.
QT Soundmodem - https://www.cantab.net/users/john.wiseman/Documents/QtSoundModem.html
Setup instructions - https://wiki.oarc.uk/packet:qtsoundmodem?s[]=qtsoundmodem
QTermTCP - https://wiki.oarc.uk/packet:qttermtcp
Setup instructions - https://wiki.oarc.uk/packet:qttermtcp
What is on the node?:
GB7KSE is connected to nobody via RF at the moment. Hopefully that will change, but it is connected to another node in the south GB7BDH, which also connects to Whatspac (WhatsApp for packet). It is also connected to VE7QBZ for now, just to test stuff out.
There are all sorts of commands to get your head round this cheat sheet is really handy. Feel free to poke about, its unlikely that you’ll break anything. Above all welcome back to 1989.
Think of it as Meshcore/tastic/whatever but with 25w and good old VHF ![]()
