What to expect from solar Meshcore nodes?
Being new to Meshcore and having just installed a solar node (a Seeed SensecCAP P1-Pro) I’m curious to know what to expect from solar nodes here in Cumbria, with our weather and darker days over Autumn/Winter.
For example have previous solar nodes in Cumbria worked throughout the winter months without loss of service, or did they fail due to poor light and insufficient charging or low winter temperatures etc?
I’m aware of the rock nodes being in use, but unsure if any other types of solar have been tried last year?
Any info would be appreciated about results experienced so far, thank you
Philip
I’ve the same repeater,mine has high draw vape batteries installed it been up just over a year and never drop below 93% yet
Thanks Mike,
That is helpful to know. My solar repeater was losing about 1% per day battery, I went back there yesterday and adjusted the solar panel to around 30 degrees, it had been at 45 degrees.
This morning it hasn’t gone down further and remains at 89% same as yesterday.
I may have to relocate my solar node as it is in an area of thick woodland to avoid it being found, but lacking clear unobstructed view of the sun throughout the day may be a compromise too far.
I am going to look for a new location later this morning
Philip
Adjusting the solar panel must have made a difference, as today the % battery is rising, despite quite a lot of cloud cover
A victim of my own success, it seems I found too good a location for my node/repeater as it has been repeating so much traffic from the likes of the superbly well sited gb-ev-rpt that the battery capacity dropped alarmingly in one day to only 70%.
When I checked how much traffic was passing through, using Meshcore Navigator, it was shown as very high in comparison with other nodes.
I have now reduced the output Tx power from 22 to 17, that apparently saves 30% Tx power without significantly reducing range.
I have also reduced the adverts frequency to the longest possible settings.
Today the battery voltage went up by only 1% despite it being quite sunny.
I have also temporarily blocked 1 byte messages, whilst still allowing gb-cum and cax 3 byte routing.
I also went up and checked the solar repeater to make sure a squirrel wasn’t sat on the solar panel!
Hoping these changes will bring about a battery charge surplus to get back up to the maximum 96% it had at first.
some days just be like that. i wouldnt worry too much as long as it can get back up to a high level. best to watch its values over a few days to see if it evens out. admittedly winters approaching so you’re doing right keeping an eye on it.
